Sean_Boburk
Sep 21, 2015Explorer
Unless you put a larger diameter tire on, a 14 and 15 inch rim will turn the same speed...
If you put a noticeably larger diameter tire on...you will need to adjust the hitch, and may have some other problems (clearance between tires, brakes will wear faster, stabilizer will be further extended....less stable...)
Sean
Sean
44,029 PostsLatest Activity: Jan 28, 2025
