d3500ram
Feb 21, 2018Explorer III
I went through this dilemma in trying to figure out the best options for me. In the end, I went with a one-size larger tire as noted in sig. The larger Load Index gave me the comfort I needed for the weights after a very thorough analysis. I could never find an actual documented capacity of factory wheels but I could safely assume that factory rims will be at least capable of the tires around them from the factory.
In the end, I determined that my steel wheels are carrying and extra #75 each over the conservative assumptions I made.
In researching the 19.5's, I found that if one sticks to the smaller diameters that gear ratios are not really affected too much, the larger options would change it some.
Pros for 17":
-less costly
-maintains stock design configuration from the factory
Cons for 17":
limited LI availability
Pros for 19.5:
obvious from the conversations in the TC forums.
Cons for 19.5:
MUCH heavier unsprung weight- tougher on suspension and brake components.
Backspacing and offsets do not match factory wheel specification.
Pros for 17":
-less costly
Cons for 17":
Pros for 19.5:
Cons for 19.5:
44,071 PostsLatest Activity: Aug 16, 2026
