jerem0621
Dec 23, 2013Explorer II
facory wrote:
Aluminum frame is lighter than 'stick & tin' built. Also consider the type of outside covering. A smooth fiberglass/gel coat exterior is easier to maintain and clean. You will find this on the Aluminum frame trailers.
*not always 100% true*
Lots of tin skinned trailers have aluminum framed walls.
The wall construction also has a lot to do with the weight. Fiberglass can weigh more than Adzel etc. Just depends.
Also, the chassis can contribute to the weight. Is the frame a 4 inch frame or a 6 inch? C channel or tube construction... Axles etc. There is more to weight than sticks vs aluminum.
Also, the slides can weigh a lot. Just depends on how they are constructed.
I had a 31 ft long 8 ft wide sticks and tin TT that weight about 6500 lbs loaded.
No slides though ;)
Thanks!
Jeremiah
