Grit_dog
Aug 31, 2022Trailblazer
TheOMB wrote:
My trailer had 4, D load range tires. From advice of many friends I've up graded to E load range. Just got a set of Good Year Endurance with max PSI of 80. Previous tires and trailer sticker says PSI 65.
Should I run 65, 80 or other PSI?
Visually the Load Range E look better at 80 PSI without a slight bulge.
So none of the 3 pages of responders can even give you any sort of sound advice as you haven't even posted what the trailer axle loads are (approximately, at least).
Some responses off topic, others, a reflection of anecdotal experience, and others, well, I'm not sure....
I can't answer your question either, since I don't know even remotely what your axle loads are, but reasonably, if D load tries were sufficiently carrying the load as designed at 65psi, then you have zero need to raise pressure beyond what you were running before, regardless of whether the tires have a greater max psi rating.
Trailer tires do NOT necessarily need to be run at max sidewall pressure, if the tires are rated significantly higher than the load they're carrying.
The weekend warrior, less than informed responses, will tell you that even though it is 100% untrue.
Post your weights, or find them and use a load pressure chart and decide for yourself what is acceptable by design (the chart) and what feels good going down the road.
