javatoto
Sep 09, 2022Explorer
Hi hey you did great getting load range E. Ill tell you what I found to be true. If your bit over weight drop tire pressure 8-12 LBS also if hot outside drop pressure 8-12 LBS from stated psi 80 in your trailer. I run 68-72 all the time. Before les Schwab guys would tell me 80 but kept blowing tires 5-6 per year Yeck. Someone finally said to drop pressure and now I almost forgot how to change tires! Yeah. Also get you a ramp when you have a blow out you'll just put behind the back wheel if front wheel blown and back up on to ramp instead of trims Jack leave busted wheel hanging. Be sure to loosen lugs before backing onto ramp. Fast easy safe
