MFL
Sep 09, 2022Nomad II
javatoto said: "If your bit over weight drop tire pressure 8-12 LBS also if hot outside drop pressure 8-12 LBS from stated psi 80 in your trailer."
These statements make no sense! Overloaded ST tires will handle less load, with reduced air pressure.
ST trailer tires with 8-12 psi reduced pressure will run even hotter, in extreme heat.
Is this maybe just a troll first post?
Jerry
Jerry
