theoldwizard1 wrote:
adamis wrote:
5. Built in Battery Monitoring System prevents over charging / discharging so less to worry about.
So no change in any of your charging equipment ?
Nothing planned at the moment. These are designed to be drop in replacements and will work with existing charging systems from what I was told. The internal BMS will prevent any over charging. I think part of the reason this works is because they are able to take a lot more current and higher voltage than standard lead acids allow for. To get the maximum capacity out of them I am sure I will have to upgrade the chargers that have LiFePo4 profiles but that will be another day.
