adamis's avatar
adamis
Nomad II
Sep 04, 2018
Pulled the Trigger on LiFePo4
After much thought and a few posts in the past, I have finally pulled the trigger on a 12v, 100AH Battle Born LiFePo4 battery for my 2001 Bigfoot 10.6. It will be arriving on Wednesday and I will be installing it on Thursday. Instead of purchasing on Amazon, I called them directly. I was able to get a $50 military discount they were kind enough to offer and saved on Sales Tax as well (out of state). Out the door for $899.00. Now before everyone gets excited about how I could have gotten twice the capacity for half the cost, I had reasons for going this route...
1. Able to remove camper from truck. My old 6v 300AH Lifelines were stored in the bed of the truck requiring a long umbilical cord that had to be disconnected if I removed the camper.
2. Saved 150lbs of weight (30 lbs versus 180 lbs for AGM).
3. Able to use existing battery compartment that is limited in size on Bigfoots.
4. Wanted something that could charge faster than my AGMs
5. Built in Battery Monitoring System prevents over charging / discharging so less to worry about.
6. Usable capacity is probably higher than my 300AH AGMs that I could only draw 150AH from to be safe and considering they were 10 years old, probably had less than half of that capacity.
In regards to cost, yes, it was more than had I gone with AGMs but I had some points on my credit card to use up so this really cost me $500 out of pocket and the benefits I think were worth it.
I'll post my experiences on this thread over time so others can learn from my early adopter experience.
And now for some photos of the install... I took some comparison images of a standard car battery as well as my old 6v Lifelines. I haven't measured it yet but I think it might be possible to get two of these into the Bigfoot battery compartment. I think one will be sufficient for me however.
  • Freep wrote:
    What is the lowest temperature they can be while charging?
    Not positive on temps. The specs page is here.
  • What is the lowest temperature they can be while charging?
