jbres's avatar
jbres
Pulsating Brake pedal. HELP!
I have a 2003 Tahoe. About 30,000 miles ago, I replaced front brake pads and rotors, and rear pads only. NOW, I am getting some SLIGHT pulsating when applying the brakes gently. When applying them hard, don't really feel anything.
I have no ABS light on, and when I visually look at my rear rotors they do have some "grooves" or "streaks" going through them. They are not in perfect flush shape.
Is my rear rotors the problem?
Thanks!
  • The junk I've seen come out of parts houses now days I would wager the "new" front stuff is warped.
  • terryallan- how do you have them turned? Would it be cheaper to just buy new?
  • Sounds like you have at least one warped rotor. Could be the rear. Have them turned and see if it stops it. Won't take long.
