BossCamper wrote:
That looks like a handy mod, but I'm wondering how you caused a flood by forgetting to turn off the pump. Did you forget to turn off a faucet too?
My kitchen tap has a gooseneck, it will rotate 360 and the taps are feather light to the touch. Had a pee break, forgot the pump, hit rough road, gooseneck rotated & tap turned itself on. 1/2 tank of fresh water inside. Fortunately it was in Arizona an 95 degrees with 5% humidity. I had to cut open the underside and pull out all the soaked insulation. It was a $1500 repair bill to pull the tanks to get at the rest of the soaked insulation and repair the underside & re-insulate.
