kcstrom
May 11, 2022Explorer
Thanks for the responses and thoughts folks; sounds like I should probably look at a smaller trailer (don't really want to buy new trailer and new truck at the same time).
I realized I left some info out of the OP:
* GCWR is 12,100 from the 2013 Ram 1500 Towing chart (my links are removed from some reason, guess I'm too new)
* 6'4" bed
* Rear axle ration: 3.21
I wasn't using the GVWR of the trailer since I would make sure not to put 2300lbs on it. If I have a smaller trailer with a lower CCC, I would be limited by how much I could put on there.
GCW left from truck itself for trailer would be 12100 - 6060 = 6040. Add 350lb for family to truck = 5690. Hmm, I guess I didn't do this arithmetic before convincing myself I really wanted this trailer. Dang it. This math would work out a lot better if I didn't have 8-speed transmission with the lowest axle ratio. 6-speed transmission with its lowest axle ration would have increased GCWR and towing capacity by 2000lb.
* 6'4" bed
44,071 PostsLatest Activity: Aug 30, 2026
