valhalla360
May 11, 2022Navigator
kcstrom wrote:
Thanks for the responses and thoughts folks; sounds like I should probably look at a smaller trailer (don't really want to buy new trailer and new truck at the same time).
I realized I left some info out of the OP:
* GCWR is 12,100 from the 2013 Ram 1500 Towing chart (my links are removed from some reason, guess I'm too new)
* 6'4" bed
* Rear axle ration: 3.21
I wasn't using the GVWR of the trailer since I would make sure not to put 2300lbs on it. If I have a smaller trailer with a lower CCC, I would be limited by how much I could put on there.
GCW left from truck itself for trailer would be 12100 - 6060 = 6040. Add 350lb for family to truck = 5690. Hmm, I guess I didn't do this arithmetic before convincing myself I really wanted this trailer. Dang it. This math would work out a lot better if I didn't have 8-speed transmission with the lowest axle ratio. 6-speed transmission with its lowest axle ration would have increased GCWR and towing capacity by 2000lb.
GVWR =/= GCWR
- Gross Vehicle Weight Rating (Truck by itself or trailer by itself at max loading)
- Gross Combined Weight Rating (Total of both truck and trailer combined at max loading)
Though you will struggle with the GCWR as you found. Keep in mind battery, propane and water count against the trailer payload, so the odds of you staying within the GCWR is basically nil before you add clothes, food, cooking utensils, kids bikes, firewood, etc...
But that still leaves the GVWR as a potential issue....If the 6800 GVWR I found online is correct (check the sticker on the door jam), you have less than 400lb of payload in the truck, once you put the family in it. That's way too light of a hitch weight assuming you put nothing else in the truck.
If I already had the truck and was legitimately within a couple hundred pounds, I might try to make do but you are likely going to be over by 800-1000lb if you are very strict about not taking anything unless it's absolutely needed. If you aren't careful, you could easily be 1500-2000lb over some of the limits. That's not something I would be comfortable with.
44,071 PostsLatest Activity: Aug 30, 2026
