Bandit400
Oct 22, 2020Explorer
Bedlam wrote:
If you have Class 5 truck like mine, the suspension is firm enough that I do not drop the jacks unless I am removing the camper. Most of the Class 3 trucks I see drop the jacks just enogh to slightly unload the suspension to make a firmer foundation when walking around inside the camper. You do not need drop jacks to deploy slides.
The camper can be solely supported by the jacks when off the truck whether filled with water or empty. Some people prefer to add a backup support under the bed to reduce movement on the jacks and others use an anti-wobble system from StableCamper or Torklift to stiffen the front jacks on swing out brackets. I do not use any additional device or support when out camper is off the truck, but there were high winds, I probably would not unload the camper on to the ground since I have 11.5K lb truck sitting under my camper with it anchored at all four corners.
The first generation of tankless water heaters were not very reliable and had a bad reputation for failures. People also complain that more water needs to be run through them before hot water is deliver to your faucet, so they are not as water efficient. The ones I have seen are exclusively LPG, so you must have propane to get hot water. On the other hand, I see many more camper using these now and have not heard about exponential rises in failures. They are more efficient at heating water than maintaining a tank of hot water plus you can have an endless supply of hot when you are on hook ups. I have the dual element LPG/electric tank in mine. With the water flow set at 1/3 volume and both elements running, I can get 15 minute steaming hot showers and not run out of hot. Recycle time between showers is also fast with both elements running, but for this type of indulgence you need a large water source, a place to discharge it and electric to run the second element.
When we go to a campground with hook ups, my camper is switched to 100% electric and I only fire off the LPG water heater for those long showers or the LPG furnace if the electric fireplace cannot keep up with the cold (electric good for about 20 degrees Fahrenheit external temperatures).
Thanks Bedlam, really helpful info:C If I end up using it as much as I expect, I may follow your route in a year or two and pick up a dedicated Ram5500 Crew Cab/Chassis with custom bed. The extra payload and towing capability would be welcome for those longer trips or where I want to bring extra toys. First thing first :)
