kaydeejay
May 20, 2014Explorer
onelv wrote:First of all, welcome to the Forum.
Hi Everybody,
This will be our first TT. I've only towed tent trailers in the past. I was hoping for your advice if towing a 31BHPR (Premier by Ultra LIte by Bullet) will be too big of a jump? It weighs just under 6500lbs.
Also, is our set up safe? - My two vehicle is a 2014 Mercedes GL350 (diesel) with max tow of 7500lbs.
I appreciate any advice.
Thank-you
If that 6500# is the empty weight, figure 1000# more once loaded.
And that 7500# tow rating assumes a 150# driver in the vehicle. Any more than that has to be subtracted from the 7500#.
Can your GL350 available payload rating handle a 1000# tongue weight along with all occupants and "stuff"?
I suspect you are going to over your ratings, both GVWR, GAWR and trailer weight. Maybe even hitch ratings as well.
Towing would likely not be a fun experience.
