AH64ID
May 21, 2014Explorer
hbillsmith wrote:
Ah64id the Anderson is the perfect WDH for the Mercedes GL. I should know because that is my setupand I tow a TT about the same specs as the OP. My experience has been about 350# distributed to the front and back to the TT. Verified several times with triple CAT weights (car only, attached with WD, attached no WDH)
That's the most weight transfered with an Anderson, most only report about 200lbs.
What are your 3 front axle weights?
