AH64ID
May 26, 2014Explorer
hbillsmith wrote:
Here you go 2010 Mercedes GL450, 2013 Kodiac 242RESL, Anderson WDH
Axles Front Rear Trailer TOTAL
CarOnly 2980 2820 n/a 5800
CarNoWD 2700 3680 5580 11960
Tongue Calc +2700+3680-5800=580 Tongue Weight
Car+WDH 2880 3460 5700 12040
Tongue Calc +2880+3460-5800=540 Tongue Weight
(really hitch impact, WDH does not change tongue)
WDH
Impact +180 -220 +120 =300 moved
Question. Was this all on the same day?
The reason I ask is because the GVW is different(a bit more than I normally see doing the same measurements on a heavier setup), and WDH will have zero effect on GCW. All the weight is still there, just moved. It's also odd, and not really physically possible, that you took 220lbs off of on axle, but added 300 to the others.
It is also possible it was the same day and the scale was off a little.
Even thou you added 300lbs to the FAW and TAW, only 220 came off of the rear axle. To me, and from what I gather most people, that's a transfer of 220lbs, not 300.
Good data collection thou, just some weird number and curious on your thoughts/input on the math discrepancies.
