notsobigjoe
Dec 18, 2021Nomad III
The anchors are metal and rusty no big deal. They look pretty straight if not perfectly straight, Maybe bent a little from the pull of the rear jack. The pic might be fooling us. Get a better pic of that rear anchor cause they are a pain to change also if it's pulling out that could be a sign of trouble. The camper leaning down at the rear in the bed of the truck is also petty normal too. I know that some years of Chevy they had a slight slant to them to drain water. I don't know of other brands though. My final thought is I think the camper looks pretty solid. I would absolutely take the advice of all our members and go over it with a fine tooth comb and look for any water damage. I bet you won't find much. Also take a look at the cushions and mattress to see if they are moldy, start everything, run the heater, AC, hot water heater, lights, running lights, backup lights, plug to the camper, etc... Otherwise I think it's a good find. Good luck sir.
