wowens79
Mar 29, 2021Explorer III
Gdetrailer wrote:
Can't figure out if you are serious or joking.
How are you planning to pick up the tongue? There will be considerable amount of weight on the tongue to deal with which would require some sort of wheeled dolly.
Then you have the issue of trailer bumpers being nothing more than 20 ga sheet metal, you would have to reinforce that considerably..
Perhaps consider a Motor Home instead of a trailer, then you can simply drive it into position..
You will end up wrecking a trailer attempting to push from behind..
Of course there will be a bunch of folks posting they do it all the time..
I think it is a pretty good question as I’ve been in a couple of sites I’d like to do that, and have manually done it when I had a pop up.
The silly suggestion is to buy a motor home to permanently park.
44,071 PostsLatest Activity: Aug 16, 2026
