Bionic Man wrote:
They are very nice to have, but not imperative if you are running your truck stock. If you are going to get gauges, I would look at a fuel pressure, EGT, tranny temp (if auto) and boost. IMO, EGT and tranny temp are the most important, though the others are useful as well.
I agree with Bionic Man. With the third generation Dodges, I am not sure how critical they all are.
From 1995 through 1998 (12-valve), I would want at least an EGT and tranny temp (if auto). The boost will be of value if you understand it. The fuel pressure is nice to give you a warning of fuel issues, but not critical on a 12-valve.
From 1998 through 2003 (24-valve), I would want at least an EGT, tranny temp (if auto), and Fuel pressure. The boost will be of value if you understand it. The fuel pressure is nice to give you a warning of fuel issues from the lift pump, which in turn can destroy your injector pump.
I have very little knowledge on your 2006 Dodge. I will say if it is an auto transmission, I would want a tranny temp gauge, especially if I tow in the mountains.
With the older Dodge transmissions, you build up heat real quick backing up for any length of time. You cool the transmission in neutral, not park or in gear while parked.
I have a highly modified 1996 (12-valve). I have fuel pressure, EGT (two), transmission temp (two, pan & torque converter) and boost. I use them all with my TC loaded, especially when flat towing my Samurai in the mountains. I have over 257,000 miles on my truck, with the original engine. It has not been in the shop, except transmission, since 2003.
Wayne
