RedRocket204
May 30, 2016Explorer
smkettner wrote:
Do check the interior install. Remove the interior trim and take a look for poorly sealed transition to the ducting. Also verify if you have a plenum divider that it is well placed and sealed properly. This divider separates the air coming in and going out. If it is not installed well some of the air can just circulate within the unit.
Bingo. Exact issue I was having after the TT has shifted multiple times from traveling. Just needs a "tune-up". I did what was recommended and sealed the area really well with aluminum tape and it made a big difference.
Roof AC not cooling properly. Check, test and fix
