Larry,
Here is a Ford chart for Ford's recommended coolants.
https://www.fcsdchemicalsandlubricants.com/Main/quickref/scucEN.pdfI don't have time to find the links now, but I remember reading that Ford failed to provide factory installed anti-cavitation additive in it's early International rendition diesels. They were not sleeved, but ordinary castings. Nobody at Ford knew about it and some early engines failed after high miles because of it. International supposedly provided the chemical in their own truck in the form of replaceable coolant filters, but Ford didn't use a filter to save money.
Ford has an additive, VC-8:
http://www.amazon.com/Genuine-Ford-VC-8-Cooling-Additive/dp/B000NU3LPSMore here:
http://www.ford-trucks.com/forums/1064454-check-coolant-additive.htmlDieselManor has an add for such a supplement here:
http://www.dieselmanor.com/fleetguard/DCA60L.htmTheir reasoning is not what I understand it to be. My understanding is that the cavitation is caused by the diesel ignition accoustic shockwave that forms momentary rarifaction/compression in the coolant liquid next to the cast cylinder.
The following makes sense to me:
The cylinder actually slightly expands and contracts from combustion shock. This causes bubbles that collapse very violently, violently enough to minutely spall the metal (like a reverse windshield chip). Unlike a windshield with double layers, the cast iron eventually chips all the way through which causes pinhole leakage between the combustion and coolant. The additive merely coats the cast iron wall with a jell that softens the blow. It does seem logical to me that modern diesels with multiple injection can soften the initial blow enough to possibly be immune to the problem. The common observation is the reduced noise from a mild pre-ignition before full charge is injected; i.e. "quiet" diesels.
I'd be interested in links you may have that discuss cavitation more fully. There is apparently a lot of misunderstanding about the phenomena. I'll get back later when I have more time.
Wes
