rhagfo
Nov 20, 2014Explorer III
shum02 wrote:rhagfo wrote:
The thought of having to change oil in a diesel at 5,000 miles with full synthetic just does not sit well with me.
I am not saying the 6.0 can't be a strong engine, just the maintenance is too costly for a diesel.
Well I have an option of taking my truck to Cummins NW. I also have the option buying OEM parts from them also, which are usually less expensive that parts house or dealer.
Ummmm, where does it say the 6.0L requires synthetic??? Dino 15W-40 resides in mine per the manual during the warm months then I switch over to 10W-30 semi synth for the cold weather as per the manual - you can use full syth if you want and extend out the drain interval if you have it tested. Think that just about goes the same for a Duramax or Cummins, right? I ALSO have the option of heading over to IH to buy OEM parts for the 7.3L/6.0L/6.4L as well. Fact is I rarely ever buy from the stealership unless I can't get it anywhere else. Fact is as most do I buy my parts online.
Seriously, put a little effort into your research, you sound like a "fan boy" on one of the truck forums.
Didn't say it came from the Owners manual, it was stated in this post.
Rosebud wrote:
I have a 2005 6.0, and love it. Just returned from 15,000 roundtrip to Alaska. Pulling a SunnyBrook 31 BWFS and no problems except with the brakes on the 5th wheel. Truck preformed just fine. I did replace the EGR cooler and oil cooler at 95,000 miles. I think this truck is one of the best I have ever owned. Love driving it.
It is true that the market is depressed on the 6.0 powered trucks but they can be a good deal. Regular maintance is a must, use Motorcraft filters and Synthetic oil, (I use Rotella T-6). Change coolant regularly and enjoy your ride
Bill
I run 10,000 miles on Dino Oil and Blackstone reports I could easily go 12,500 and still be protected.
