Turtle_n_Peeps
Nov 21, 2014Explorer
W4RLR wrote:Turtle n Peeps wrote:T&P, you might want to read your own link!
The 6.0 was replaced in 2008 with the 6.4, which had fewer issues, but was a fuel hog.
The 6.0 and 6.4 are based on the same basic design, but is a slightly larger displacement. It also had many emissions related changes. Ford and Navistar did work to improve the 6.4, but it was a fuel hog.
This would be like saying the Cummins 5.9 and 6.7 are the same engine. Yes based on the same basic design, but many changes for emissions.
Gesus, I get home from work and see this mess. :S
Here, let me quote it for you:The 6.0L Power Stroke was used in Ford Super Duty trucks until the 2007 model year but lasted until 2009 in Ford Econoline vans (Model year 2010).
Now, see where the 6.0 lasted until the 2010 year model exactly like I said it did? :R
Oh brother...the 6.0 engines on the E-series vans were derated and did not have near the problems experienced by the pickups, which had different tuning. The last 6.0 in a pickup was in the 2007 model year. By 2005, most of the problems with the 6.0 were resolved. The ONLY reason that the 6.0 was replaced with the 6.4 was due to EPA emission standards that the 6.0 couldn't meet. Ford got an exemption for the E-series vans as the 6.4 wouldn't fit in the van. When the 6.7 engine came out and wouldn't fit, Ford no longer offered a diesel in the E-series. You CAN get a five cylinder PowerStroke in the new Transit van, the first Ford van with a diesel in several years.
You're a Ram guy, aren't you Turtle?
Exactly. according to Ford's own engineer, Ford went over s spec on the cylinder pressures of their 6.0 pickup engines. The van engines were left as Nav wanted them to be tuned and it shows big time.
As evidence of that. In June 2006 after the 6.0L had been in production for over four years (and only six months before the end of widespread production)- Ford engineer Mike Frommann emailed regarding on of the “usual suspects,” the head gasket:
Fords engineer Mike Frommann wrote:
We unfortunately exceeded our own cylinder pressure specs in normally performing engines. We don’t want to have our cylinder pressure specs published or documented by having them subpoenaed or we might face a class action. When we have a defect, we have to honor our warranty…..I recommend we all delete these emails.
Sorry, not a brand fan of any particular make or model. I just call it like it is. You being on this board long enough should know that. I own a Chevy and a Dodge and race several Fords.
Unlike some on this board I don't recommend junk. I would not recommend an LB7 unless the injectors were replace with factory ones because the first gen injectors from Bosch were junk and very expensive to replace.
Controversy, I do recommend Fords V10 and 7.3 diesel. Great engines and last forever.
As far as people saying that they have x amount of miles on their 6.0 and have no problems.............it means nothing. Nothing at all. I have several 5.7 diesel and they never gave me any problems. It does not change the fact they are junk and always will be junk. Fact is, their junk.
Like I said, I just call it as it is. I'm not making these remarks about the 6.0, Ford did. Does it make you mad or do you disagree with them? Go take it up with Ford because they are the ones that said it. :)
