blofgren
Nov 21, 2014Explorer
blofgren wrote:W4RLR wrote:Yellermanx wrote:I second this thought. If it doesn't have a blue oval on the grille, I don't want it. I'm on my second Ford diesel, and the only reason for that is the first one was sideswiped on a mountain road and had the rear axle ripped out from under it, totaling the truck.
Fear not, like everything on the net the 6.0 problems are severely overblown. That and Ford haters.
Leave it and all diesels stock like the real engineers designed them.
I used to think this as well. I bought a 1994 F-150 new, 1996 F-250 7.3L new, and 2003 F-350 6.0L used. I didn't have any major issues with the 6.0L on my dime but Ford replaced the head gaskets, exhaust manifold gaskets, rear main oil seal, and IPR under warranty. I also spent $3500 on "bulletproofing" to keep it reliable that included EGR delete, regulated fuel return system, turbo drain tube, upgraded FICM, and coolant filter. I absolutely loved the F-350 but it was running rough cold (I'm sure it had some injectors going bad because I had the latest inductive flash), had a leaking bedplate which constantly dripped oil on my garage floor, and I needed a bigger cab. I seriously thought about a new Ford 6.7L until I read about some serious issues that some people are having with that engine including high pressure fuel pump failures that Ford refuses to warranty. I bought the truck in my signature and could not be happier. In fact I think my wife loves the truck even more than I do.
Believe me I was a true Ford man all of my life but I guess I'm getting older and realizing that brand loyalty can really lead you down the garden path. Not trying to be disrespectful, just my 2 cents worth.
Oh, and I forgot in this post, but my oil and coolant temps were approaching 15 degrees difference when not towing and exceeding them while towing so I think the oil cooler in my truck needed rebuilding/replacing as well. These are definitely high maintenance units.
