OregonMan's avatar
OregonMan
Question about lowering unhitched 2 wheel travel trailer
Hi I have a 20 foot 2 wheel 2018 wolf pup travel trailer from Forest River. It has a manual crank to unhitch and I use a cinder block underneath the metal hitch bar to give clearance for the truck to get out. This is probably a dumb question, but is it safe to lower the travel trailer once unhitched? My main concern is: is there a bunch of weight being supported by the hitch bar being propped up on the cinder block for the truck clearance? Will lowering it cause damage? My trailer is currently at a slight angle downward and would like to correct if safe to do so. Thanks for any feedback.
  • They sell jack stands for the tounge also. But as allready said, a block of wood is a much better idea. And lift or lower away!
  • Agree on the cinder block thing, but really don’t understand the question.
    Based on what I think your asking, yes use the jack to raise or lower the front to level out the trailer.
    Although you may be asking something else because what I said above just seems to obvious to bea question.
  • I second what Mitch said. I would never use a cinder block to support anything like a car or trailer. I had a shop teacher back n the 70's that would jack up his own car and place a cinder block under the frame. After lowering the jack, he would tap the block with a light hammer. The cinder block would shatter and the car dropped to the ground. I never forgot that.
  • MitchF150 wrote:
    I really would not use a cinder block... I like solid blocks of wood.
    I use a couple of 4x8 blocks that are only around 18" long and stack them.
    I can break a cinder block with a small hammer... Or just dropping it..
    The cinder block is heavier than my chunks of scrape wood, so there you go.. :)
    Good luck!
    Mitch
    Thank you!
    OP to address your question; Most, if not all people that sleep in trailers adjust the height of tongue after unhook to level front to back. The only issue is with trailer chocked tight long travel on a short trailer it can stress where the jack mounts to tongue, or try to bend jack. This stress is eliminated by a wheel on the bottom of jack.
    Now sometimes the jack does not have enough travel. Prop the tongue on blocks, then adjust block under jack
  • 999 times out of a thousand cinder blocks are fine. Do you feel lucky?
  • I really would not use a cinder block... I like solid blocks of wood.
    Good luck!
    Mitch
