- taycotrainsExplorerWell I got them and installed them yesterday...what a hassle but its done now.Wasted 2 days trying to find valve stems that would accept the new TPMS because the brand new Fomoco ones I bought where to small for the hole in the Vision rims,so I just put standard stems and Ill hit the reset button when I start the truck.I also put on a new set of brakes front and rear...Im done with this truck for now we have one more trip down to Nashville then I move the whole thing across the street to the D.O.T.yard that I work in and it becomes my snow shack for the long winter this way I have a place to sleep when the idiots in the state capitol take us hostage because it might snow more than 4 inches and wont allow us guys to go home.
Air bags next spring...
- VinsilExplorerLove mine, rhino lugs as well. Mine are black PC, and its holding up great if black is your choice.
- BedlamModerator
Artum Snowbird wrote:
I bought Rhino nuts to use with mine. A bit salt flaked from winter, but still just fine. About 7 years now. You also need to watch the caps that come with them. I had to use a hole saw to drill mine for my Warn hubs, and also had to get deep caps for the back wheels.
I only ran caps on the rear.
- Buzzcut1Nomad IImine came with splined nuts
- ICamelExplorerJust remember to check the torque on your lug nuts following a tire change after the first 50, 100, and 150 miles(approx).
- jimh406Explorer IIII ran them for 8 years on my previous truck a SRW with no issues. You do need to use different lug nuts.
- Artum_SnowbirdExplorerI bought Rhino nuts to use with mine. A bit salt flaked from winter, but still just fine. About 7 years now. You also need to watch the caps that come with them. I had to use a hole saw to drill mine for my Warn hubs, and also had to get deep caps for the back wheels.
- BedlamModeratorYou need tapered lugs verses the flat face OEM's.
Buzzcut1 wrote:
Three years with no issues on my vision wheels on my F350 SRW which is also my daily driver
Will I be able to use my factory lugs ? - taycotrainsExplorerThank You for the responses ... also S Davis thanks for the picture.They look great...That picture convinced me to pull the trigger on these !
44,056 PostsLatest Activity: Jan 12, 2020
