VintageRacer
Nov 05, 2013Explorer
disconnecting the battery will protect the battery, which doesn't need protecting. The sensitive electronics are still connected to chassis ground, so if you are going to be putting stray voltage on the chassis, they are at risk. If you can't take the hitch off, make sure you have a super good ground for the welder, on clean metal and the cable and clamp are perfect. And hope...
Brian
Brian
44,066 PostsLatest Activity: Mar 14, 2015
