69_Avion
Oct 22, 2013Explorer
JiminDenver wrote:
Very nice job! Can you take it off if you wanted to go portable?
On the Eco-worthy, it would be a few dollars more ($115 instead of $102) but you can order it from a seller with US stock and get it in a week.
West
last night I was think that in my situation I could use the fresh water tank for cooling. Even when it gets hotter up there during the day, it gets cold enough at night to use the furnace. I could use a radiator of some type outside and cool the FW tank considerably and then use a second exchanger in the trailer during the day to cool things down. ( I know my usual low tech ideas)
The entire assembly can come of with the removal of one pin. The solar panel can come off separately with the removal of two pins, one in the front and one in the back.
Jim, if you had enough cool water you could use a heat exchanger to get some cooling from it, but it would take a lot of water. There are cooling systems that turn water into ice during the night time (cheap electric rates) and use the ice for cooling during the daytime.
44,070 PostsLatest Activity: Jul 21, 2026
