- jerem0621Explorer II
colliehauler wrote:
Don't really need it for towing already have a Diesel and a V-10 long bed crew cabs. This is a single cab to run around town that I might leave at the seasonal site.
With all the cam phaser issues I don't know if I could trust a used 5.4. I'm wondering about a rebuilt long block? Most of the used engines I see have high miles. I don't know what would be acceptable mileage on a used 5.4?
Make sure you get a 5.4 out of a superduty. No cam phasers to deal with.
Rock Auto has rebuilt 5.4's for about $2,600 ish after core charge.
Thanks!
Jeremiah - colliehaulerExplorer IIIDon't really need it for towing already have a Diesel and a V-10 long bed crew cabs. This is a single cab to run around town that I might leave at the seasonal site.
With all the cam phaser issues I don't know if I could trust a used 5.4. I'm wondering about a rebuilt long block? Most of the used engines I see have high miles. I don't know what would be acceptable mileage on a used 5.4? - Ron3rdExplorer IIIPick up a good used 5.4, drop it in and you're ready to go.
- Grit_dogNavigator IIPerfect Fummins candidate! 12Valve/torqshift is a great combo.
- METZCOOLExplorerLol,
What Mark didn't tell you is that he helped design that transmission and is a valuable resource on the Ford forums. - nohurryExplorerThrow a V10 in that puppy while your at it! :B
Mark Kovalsky wrote:
Thanks
Yes, it is a TorqShift transmission. - colliehaulerExplorer III
Tyler0215 wrote:
Wasn't sure they put it behind the 5.4. I knew it was behind the Diesel and V-10.
No you don't have to remove the cab.
Remove the radiator, shroud, and front cross brace and you will have plenty of room to remove the engine.
Don't know what your asking about the transmission. - Mark_KovalskyExplorerYes, it is a TorqShift transmission.
- Tyler0215ExplorerNo you don't have to remove the cab.
44,049 PostsLatest Activity: Aug 31, 2025
