Geewizard wrote:
What you need to do is buy a pickup that isn't labeled as a 1/2 or 3/4 ton pickup....like a Toyota Tundra double cab 4x4. Then you can put whatever you want on it and you're good to go!
That tongue-in-cheek comment is just that. I'm 500-700 lbs over the cargo capacity of my Tundra. Have been since 2004 and 110,000 miles ago. Guess that makes my Tundra a 1-ton pickup. :B
And I have a bathroom.
PM me if you want details.
Full disclosure don't you have the smaller version of the Apex designed for Toyotas. Does Outfitter still make that one?
Your 5-700lb overage, while not ideal, isn't that bad on a 1/2 ton but pretty much all the other bathroom equipped campers would be well over 1000lbs too heavy.
