ScottG wrote:
They do indeed have the sender attached to them but there are metal variants available. Just have to Google it and you'll have some options.
Thanks Scott,
I have been looking for some and not having any luck. I was looking way before posting here. I'm not having any luck as I'm looking to get longer valve stems and don't want the braided ones. Want to stay with metal all the way and with out screw on extensions to come out of the outer wheel hole. I can then get some of the rubber donuts that hold valve stems in place in the outer wheel.
With this setup I can run my TPMS system on all 6 wheels on the Ram so I can have an alarm system. It does not appear that the dually stock ones alarm and just monitor the pressure. That is fine but I don't want to tie up my in dash up with tire pressure all the time. I normally keep up the monitor that checks the water, trans and oil temps.
If you happen to know were I could find them I would appreciate the info.
I just ordered metal valve stems for our new 5er that had high pressure rubber ones on it. GRRRRRR Hate it when they want to use rubber one on 80 PSI tires and that is the recommended pressure. I won't run my TPMS on rubber valve stems.
Thanks
