plasticmaster's avatar
Nov 17, 2015
Question on accessing underside of TT?
I have a Jayco TT and am repairing damage from a water leak. I need to access the underside of the camper to remove any wet insulation. The underside is enclosed with corrugated plastic. How difficult is this to remove and get to the wet insulation and underside of the plywood flooring? How difficult is it to then put it all back together? Thanks.
  • Remove the screws holding it up and its off. Mine has a few places where holes were filled with expanding foam insulation. Use a serrated knife to cut the foam as needed. Put up the coroplast with the screws and spray in more foam.
