spike99
Oct 15, 2013Explorer
For a little utility trailer < 1,500 lbs, probably don't need a brake controller. For a TT over 3,000 lbs, I would install a Brake controller in the TV.
Actually, do investigate the towing laws within the region you plan to tow. Some regions use minimum 1,500 lbs law and others use 3,000 lbs law.
As a minimum.... If your attached "loaded" TT is over 3,000 lbs, I would recommend a Brake Controller (within the TV) and ensure trailer brakes are working properly as well...
Trailer brakes save lives.
