Mr_N's avatar
Mr_N
Question on Dexter hydraulic brake actuator
Picked up a new to me trailer with the dexter hydraulic brake actuator and 8k oil bath axles with drum brakes.
However the wiring is unique to the last owner, or I am unsure of the standard.
I tried to follow the Dexter instructions on wiring but the main power wire seems too small on the trailer. However before I trouble shoot that I have question.
Should the pump only run when the brakes are applied?
Mine runs all the time an goes under load when the brakes are applied. The kicker is the hydraulic unit runs always when hooked to the tow vehicle.
  • have you checked on dexteraxle.com for information
    as they have all the service and setup manuals there
  • Turns out my Tekonsha Prodigy P1 doesn't work with electrical hydraulic brakes.
    Nor does my draw tight
    Off to purchase a new brake controller
    Thank you eHoefler
  • eHoefler wrote:
    Your brake controller may not be compatible with electric over hydraulic.
    Great point.
    I will see if it has 5 amps
  • Your brake controller may not be compatible with electric over hydraulic.
