pennstaterv's avatar
pennstaterv
Electric over hydraulic actuator
Looking for anyone who has installed an electric over hydraulic actuator... I am finishing up my disc brake conversion but have a question about the actuator wiring..
I have a Hydrastar actuator with 4 wires ---
yellow wire goes to cold side of breakaway switch
white to ground
blue to brake controller
and black is 12v power for the electric pump
Now, instructions require a 25-40amp 12v source for the black wire... my F350, however, is only fused at 20amps for the trailer plug. I talked with the folks at etrailer and they were surprised to have never heard this issue before.... especially considering I have a very common truck.
Anyone used this set-up without a problem? I am guessing my only other options would be to replace the truck wiring or add a second 12v wire fused higher and run back to my trailer....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
