I just installed a Reese dual cam hitch this weekend. Yes, you can just add the dual cam part to what's shown in your picture. The cam brackets are bolted in at the bottom of the trailer tongue, so those aluminum boxes will not be in the way.
If the picture shows your trailer, the Reese instructions say that the lift up brackets should be positioned so that the chains are vertical, in order to avoid damage to the brackets. Your chains are tilted forward because the brackets are moved forward due to the tongue boxes. Something you may have already considered but wanted to point it out.
