ScottG
Jan 20, 2020Nomad
Some seals are designed to be used with the EZ lube or in the case of marine stuff "Bearing buddys" style grease system and are built to take the pressure (in theory..) created during the greasing process. Those seals cost more.
If you don't use that "feature" then the cheaper, more common seals work fine for RV's but for a boat trailer, I'd get the better ones becasue they have a tighter seal.
Scott
Scott
44,070 PostsLatest Activity: Aug 07, 2026
