Old-Biscuit
May 22, 2016Explorer III
Recent Exclusion of horizontal DOT tanks:
Owners of older RV's that use horizontal rather than vertical propane cylinders should read the following information:
The new OPD (Overfilling Prevention Device) valves will be required on 4 lb to 40 lb propane cylinders from 1 April 2002. However, the currently available new valves are designed only for vertical cylinders and cannot be used with horizontal cylinders. Therefore, horizontal cylinders manufactured prior to 1 October 1998 have been exempted from having OPD valves, provided they are so labeled. (Such cylinders manufactured after 1 October 1998 do already have OPD valves).
Since propane dealers do not seem always well-informed, it is suggested that RV owners with pre-1998 horizontal DOT tanks should print this article and carry it with them, in case a dealer balks at filling a cylinder without an OPD valve.
The relevant part of the document is on the second page:
Q: I have a horizontal cylinder on my recreational vehicle. Are OPD's available for that kind of service?
A: The 2001 edition of NFPA (National Fire Protection Association) 58 (the LP-Gas Code) recognizes that horizontally oriented cylinders that were manufactured prior to October 1, 1998, are unable to be retrofitted with the OPD's. As a result of this fact, the Code now exempts these cylinders from having to be retrofit with OPD valves (NFPA 5.7.3.5). Any such cylinder must have a label affixed to it to inform the user and the refiller that an OPD valve is not installed (NFPA 5.7.3.6)."
Reference:
NFPA 58
Chapter 5 LP-Gas Equipment and Appliances
5.7 Container Appurtenances and Regulators
5.7.3 Overfilling Prevention Devices
5.7.3.5 Exemptions
5.7.3.6 Labeling
Reference:
NFPA 58
5.7.3.5 Exemptions
5.7.3.6 Labeling
44,056 PostsLatest Activity: Jan 12, 2020
