HMS_Beagle
May 23, 2016Explorer
While they may not need OPD valves, they may need recertification. There will be a date stamped on the tank indicating when it is needing recertification. Done properly, this is a pressure burst test: they are filled with water or other liquid and pressurized to a proof pressure far above what propane will do. Liquid is used because if they burst during the test, it is undramatic compared to a compressed gas. Then the tank will be dried and stamped with a new certification date. It is usually around $20 - 30 for each tank. Not worth it for a cheap 20 lb vertical, but probably well worth it compared to new for horizontals.
44,056 PostsLatest Activity: May 04, 2014
