pira114's avatar
pira114
Explorer II
Feb 24, 2015
Question on surge protectors
Howdy again.
So I'm thinking about a surge protector. Like the Progressive Industries PT30C 30 Amp Portable Electrical Management System.
Obviously, my TT is 30 amp.
So the question is that when 50 amp is available, I would use the reducer and plug into the 50.
So I'm guessing this PT30C wouldn't work in that scenario?
Do they make one that works with both?
Or is a wired in protector the better option?
Sorry is this has been covered. I did a search and didn't see this specific set of questions answered, and I'm horrible with electricity.
Thanks
  • Wired in unit allows you to monitor electrical conditions from inside your trailer. I went with the portable 30 amp unit and it has worked well for us. I use a cable and lock to provide some security. It's nice to know that the electrical service is OK before you plug in your trailer and risk having any problems.
  • I have the EMS-PT50C and have used on a 30 amp service and you can use your PT30C on 50 amp service, just use the correct adapter. When the EMS-PT50C is used on 30 amp service only one leg is used and when a PT30C is used on 50 amp service only one leg is used, but the adapters take care of the wiring.
