Wikel
Jul 29, 2017Explorer
mike/kellie wrote:
I'm goung with traditional frame mounted tie down brackets with my Douglass 9' body. I take mine off quite a bit and like knowing that it doesn't have to be perfectly aligned when mounted and the Fastguns have their inherent spring tension available when needed. I think I'm still 6 weeks out with my build.
So still having the typical tie downs is an option?
The hard mount install is a much cleaner look but as you've pointed out, if you remove it often... re-aligning can be a challenge.
