roaming_free's avatar
roaming_free
Question on Towing and Weight Distribution for a Newbie
Good Afternoon All,
I have been camping for the last 2 years in a popup with my wife and son, and we have been loving it. I think last year we went out about 13 times. This year we are upgrading our camper, and I just acquired a used truck as well.
I have pulled plenty of utility trailers, my light popup, and some heavy trailers (15,000-30,000) at low speeds in a yard at a place where I worked. I have a general understand of how to tow, but never with a truck and trailer that was mine where I needed to be concerned about all of the individual weights. I want to see if anyone out there can think of anything that I might be missing out on. I want to keep my family as safe as I can.
My camper is 7250 dry, 8600 gvwr, with a tongue of 900 lbs.
I will be pulling it with a 2013 Silverado 1500 that has the following (in no particular order):
GU6 3:42 rear axle
K5L Heavy-Duty Trailering Package
KC4 COOLING HEAVY DUTY ENG OIL
G80 Eaton G80 locking rear differential
C5W GVW RATING 7,000 LBS
KNP Cooling, external transmission oil cooler
JL4 StabiliTrak, stability control system
MYC Transmission, 6-speed automatic
VR4 TRAILER HITCH WEIGHT DISTRIBUTING PLATFORM
Z82 Trailering Provisions HD
JF3 BRAKE VAC POWER, 17 DISC/DRUM, W/ABS, 7,000 LBS
It does have an integrated brake controller.
I also just purchased a Curt 17500 Weight distribution and sway control ***Link Removed***. I will be paying the service department to adjust the hitch and camper for my truck.
By rough estimates, all of the weights for front and rear axels, GVWR of the Truck, of the camper, and the combined for my truck (15,000) should all be within the limits. According to my trucks manual, I have a towing capacity of 9,600. I plan to take it to a local cat scale where a very nice lady said they would assist me with taking all of the appropriate measurements for me, but they will not tell me whether or not I am in spec (not unexpected, but it is pretty simple math from there).
Is there anything else that anyone thinks that I may not be considering?
Thanks in advance for any suggestions.
