DiverDan80
Feb 18, 2017Explorer
Question: Pop-Up vs Hard-side TC's (firsthand experience?)
First off, I want to thank everyone for responding to my first/last post! Now a new question for all you TC gurus!
A little background: I have a 2001 Ford F250 Super Duty 7.3 XLT 4x4 longbed (non-dually), with stock heavy duty helper springs; am in the process of upgrading my tires for firmer side walls, adding full Stable Load kit, adding Rear Sway bar & replacing front stock sway bar both with Hellwig's Bigwigs, and getting Sumo Springs. My aim is to get get a 'light' camper, preferably w/ toilet & shower (even if the shower is just an outside shower), weighing at no more than 2,000 LBS dry, 3,000 loaded. That will enable my wife an I to be semi-adventures (i.e, not a pavement-king) and still tow my zodiac dive boat.
Hard-side (HS) VS Pop-Up (PU) TC's Pros and Cons (?)
First, I am getting the feeling that this debate has all the emotions and passions of 'Chevy VS Ford' or "R VS D', but please limit this forum for those with First-Hand Experience hauling/using BOTH. HS'ers often make comments like, "It's just a tent in the back of your truck!" (Ummm I don't have a heater, refer, stove/oven, AND bathroom in my tent!) and PU'ers say, "Why would ANYONE NOT own a pop-up??". My observations (as I try to decide between a HS & PU) are:
Hard-Sides (HS)
-Stay Warmer/Cooler
-Heavier Dry Weight (generally)
-More 'Top Heavy', w/ more Sway/roll issues, etc.
-Less Versatile (for off road/non-campground camping)
-Usually Cheaper to Buy Used than PU's
-More 'Standard' Creature Comforts
-Quieter Inside and Easier to 'Stealth' Camp/rest/eat/etc.
Pop-Ups (PU)
-Better for Gas Mileage
-Lighter Dry Weight, Lower Center of Gravity & Lower Profile
-Get Colder/Hotter Quicker
-Can be Obtained with all the 'Comforts' of HS, however w/weights approaching small HS's
-Are Harder to Find and are More Expensive to Buy Used than HS
-Easier to Drive and Store
-More of the 'Real Camping' Experience (i.e., closer to nature)
Thanks!
Hard-Sides (HS)
-Stay Warmer/Cooler
Pop-Ups (PU)
Thanks!
