Tamnative
Aug 02, 2015Explorer
AH64ID wrote:
Are you sure the front tires came off for an alignment? I don't think that is standard practice.
I would pull the wheels and compare the lug surfaces and wheel mounting surface.
Mine are on and off a couple times a year without issue.
They had to pull a tire off to check for balancing as there were no weights on the wheel,turned out that they used "beads"for balancing.
