Tamnative
Aug 06, 2015Explorer
On the front of the wheel it is milled for a conical lug nut which would be standard for all these wheels but in the back of mine it is milled 1/8"+ behind the lug hole leaving no material directly behind the lug hole making the actual thickness of the wheel that the nut clamps to much thinner thus weaker.
As far as being hub centric Vision has stated that they were hub centric wheels.
On my truck a 2005 F-350 the hub is 124.9 MM and the hole in the wheel is 125.2 MM which would mean it is .3MM larger or .012" which is about as thick as a piece of paper. I will let you guys decide if they are hub centric or not certainly close if not.
Hope this clarifies things a little.
44,070 PostsLatest Activity: Jul 01, 2022
