billtex
Aug 07, 2015Explorer II
From Visions website;
What is the difference between hub centric and lug centric? Should I use a hub centric ring?
Factory wheels have a center bore that is designed for each specific car, which places the stress of centering the wheel on the mounting hub of the car. After-market wheels are designed to fit a variety of vehicles. If mounted without a hub centric ring, these wheels will be centered primarily by the lug nuts, which can cause vibrations. It is advisable that you use a hub centric ring
Did you use the recommended spacer ring?
Keep in mind, these are heavily loaded trucks we are talking about. You need to have that load properly distributed...which is NOT on the lugs.
44,070 PostsLatest Activity: Aug 05, 2026
