Troy35
May 12, 2015Explorer
Questions about DRW tire pressure
I just purchased a Ram 3500 DRW. VERY excited about it, however, this is my first experience with DRW and I had some questions about those inside tires.
First, what method are you all using to fill them up? I plan on just getting a long rigid inflator to push into the inside valve stem. One with a gauge so I can easily check pressure while filling. I've seen other options that extend the valve stem or even tied the two tires together with a metal air hose.
What do you all think about those?
Second, I was reading that since the inside tire carries more weight than the outside tire it heats up more resulting in a higher PSI thereby making it more stiff than the outside tire causing the inside tire to wear faster. It was suggested to run 2 or 3 PSI lower in the inside tire to account for this. Thoughts??
I can find this easily enough but while I'm here...how do you rotate 6 tires?
