kevg
Apr 06, 2015Explorer
ticki2 wrote:kevg wrote:
Maybe I'm missing something, but on page 84 of that PDF, the rear axle says 6200 for a Ford F250
It is confusing , if you look earlier were it gives the payload you will see that the axle rating is being generated by the spring rate , not the actual axle rating . The 350SRW and 250SRW use the same axle , they change the springs and tires and get a higher axle rating .
Ahh, I see thanks, so basically if I want to beef up the rear, I need better wheels and springs (and rims?). Do you have any suggestions for those?
