otrfun
Jul 03, 2019Explorer II
texaspiper wrote:It would take approx. 20 amps DC to run the frig heating element on 120 vac using an inverter and, again, approx. 20 amps DC to run the frig's heating element on 12 vdc (have to have a 3-way frig to do this). The 7-pin connector wiring on most trucks are limited to about to approx. 10 amps. Unless you install larger gauge wiring in your truck you're gonna run a current deficit (with a 20 amp DC load) regardless whether you have one or two alternators.
. . . Both trucks can be optioned with dual alternators. How much use are these for the TC? Can you use them to charge batteries or say run the fridge or AC while running down the road? . . .
44,071 PostsLatest Activity: Aug 30, 2026
