deltabravo
Sep 10, 2013Nomad
Boatycall wrote:
I recently had a flat while hauling my TC, and I'm looking for comments from those who have aftermarket TPMS's.
Biggest questions I have -
* I have rubber valve stems, will the weight of the sensors degrade the stems?
YES!! I've had two flats on my dually, both were failed valve stems, and I know that the sensor caused it. First one was last year, in May, on my way home from Overland Expo. Second flat was about a month ago. This all happened on my 2009 dually, which I bought new. I used the system once I started towing, which was about 1500 miles on the truck.
Boatycall wrote:
* Will the sensor weight throw the tire balance off?
Not enough to notice, or be concerned about.
Boatycall wrote:
* I have a DRW and I also haul a 7k flatbed car trailer. I need 10 sensors. Are there systems that will be fine without a repeater?
I use this one: http://www.tiretraker.com/
I've used the sensors on three trailers: 12' Wells Cargo, 16' flatbed and 20' Haulmark race trailer. Sensors worked fine without needing a repeater.
Boatycall wrote:
* When I'm not hauling the trailer, does the system go nuts/error out because it can't read the trailer sensors?
The one I use does not go crazy when it doesn't detect the trailer sensors. It doesn't throw an alarm thinking the tire is at zero pressure. I think it shows something on the display to indicate it isn't being sensed (i.e., the signal is not present from that wheel position.)
Sadly, I wrecked the handheld remote unit last year and still haven't replaced it, so I can't remember all the details about programming it. I smashed it when i closed the ramp door of the 20' Haulmark trailer when I finished fixing the first flat tire I had.
It monitors pressure and temp.
After numerous bearing and brake problems on one wheel position of my first flatbed Jeep hauler, I wanted something that would monitor temps.
Looks like your trailer is a PJ trailer.
It's a necessary expense to upgrade to all metal valve stems.
When the camper is not on the truck, take it to Discount tire in Puyallup and have them hook you up.
Yes, I even upgraded to all metal valve stems on all my trailers. Some TPMS vendors sell all metal valve stems. When I bought my system, I was at an FMCA rally in early 2010. I bought the TPMS system direct from Tiretraker, and got metal valve stems for the trailers from a different vendor.
I was lazy and never upgraded the valve stems on the truck in the beginning. I upgraded a few last year, and after my recent flat tire (which had other issues too), and finding it impossible to get matching tires, I ended up trading in two NEW tires on 2 new ones of a different brand, and got 2 others replaced under Discount's road hazard certificate... so when that project was complete, all 6 tires have all metal valve stems now.
44,066 PostsLatest Activity: Jul 25, 2018
